5 members (Rich'sToys, Steelonsteel, wilbur53, Bill Hanlon, Ponchogl), 81 guests, and 0 robots.
Topics128,113
Posts1,056,616
Members48,450
have 53 1/2 ton longbed want to install 283 with turbo 350 can i fit it without moving steering box maybe modify exhaust header also want to use 6 lug gm rear from what vehicle? help! thanks
Had a 283 in a 50 GMC back in the 70,s. Front engine mounts with 3 speed after market shifter on the floor. Used rams horn exhaust manifolds and yes it was a tight fit by the steering gear.Larry
58 gmc 100 with 350 sbc
A 55 or 56 left exhaust manifold off of a 265 V8 will let the 283 or any small block chevy mount in the center without moving the gearbox. Many are using the Colorado/Canyon rear to give right width, friendly highway gearing, and stay 6 lugs. I prefer the drum brake early rears but others like the disc brake ones offered after 04 or 05 (guessing here).
Evan
