1 members (TPR57C),
367
Mod | | | Forums66 Topics128,159 Posts1,057,033 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | I have a '51 1/2 ton which drives - well, like a truck! I read in a post about taking some of the leaves out of the back springs to give a more gentle ride. All I have been able to find are posts regarding lower the truck which I do not want to do. Any suggestions would be most helpful. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | whatever you do short of replacing the whole suspension system, it'll always 'ride like a truck' .... removing leafs will lower it slightly, and will make for a 'bouncier' ride, not 'softer' .... you might try new shocks and car size radials - and running with some weight in the back, which is what the truck was designed for
Bill | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | I also would like a softer and less bouncy ride. I was planning on taking leafs out but now I won't. I'll try a few hay bales and see how that helps. A thread I read yesterday discussed rebuilding the seat springs and adding some foam padding with new upholstery for a smoother and less bouncy ride. Good suggestion me thinks...but new seat upholstery seems to be expensive. I'll do it anyway cuz OEM or not, I don't enjoy the ride my seat gives. | | | | | Joined: Jun 2010 Posts: 170 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 170 | I read somewhere - might have been here - that a solution is to not remove leaves, but move one or two of the short leaves from the bottom of the stack of leaves to the top. That way they don't function but the same retainer bolts can be used. Have not tried it myself. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I saw an interesting technique mentioned in "The Corrosion Lab' in Vintage Truck. Some rear springs on the heavier trucks have lower leaves that are not arched as much as the upper ones. These are called progressive springs because the lower leaves do not do anything until after a certain load value. Thus the ride stays a little softer to that point. It was suggested that changing the arch on some of the lower leaves may help soften the ride. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | truckernix is correct, the shorter leaves do nothing to support the truck until there is a load placed on them. I was also told this by St. Louis Spring who builds the new packs sold online by most the major vendors. You can de-arch the shorter leaves or remove them completely.
Daves46pu, I am probably the one who posted what you read. Stacking them on top of the pack in the rear will lower the rear by ~1/4" (the thickness of a single leaf) for each leaf because the axle rides on top of the leaf pack. You are essentially adding 1/4" spacers between the axle and pack. Same idea as a lowering block. Adding them in front does nothing because the axle rides below the leaf pack...however, removing them in front will lower by about 1/4" for each leaf. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I don't know if you have checked the bushings and shackles, I changed mine, and lubricated between the leaves, made a noticeable difference. Apparently radial tires make a difference, I haven't tried them. But mostly it's a truck, which is why it rides like a truck, an antique truck at that. That is why you don't buy a jeep to go road racing or a Porsche 911 to go four wheeling. | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | A bit early for leaves to be in the back spring.. OH, leafs... I had to through that in.
I would not remove springs.. Just my thoughts... | | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | Thanks for the replies. I am going to leave the springs as they are but, will try what brokenhead suggests and lube it all up. Yes, you are right, it is an antique truck and that's why I bought it. It's just that my back isn't as young as it use to be. | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | It's just that my back isn't as young as it use to be. I sure hear that  Try putting some weight in the back...I just stuck two bales of straw in the back...about 140 lb total...and it really smoothed out the ride.. | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | I took 4 leaves out of the bottom of my rear springs on my 46 1/2 ton and put them on top, sure it lowered it 1 in. but I put a set OF 15IN. radials on it and it rides alot smoother now,I do have to do something about the seat tho, its way too springy, kinda like a farm tractor,im thinking I might switch to a 3rd row mini van seat, to stop the bouncing, | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | My seat is bouncy too and I'll have it redone by an uphol. shop. I did put weight in the bed, though, and that did a lot... | | |
