5 members (lumbersawyer, MickeyP, greenie-reddy, 68ironhead, moparguy), 54 guests, and 3 robots.
Topics128,175
Posts1,057,119
Members48,463
back in july i got mater to run,but only with the starter engaged, so i searched and found this old post,
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=694384
i hot wired it as the old post said to do and it ran great, but it then burnt up the coil, so i got a new ballast resistor and coil and it still does the same thing, i have all the wiring done correctly so what do i do now?
Indy wink
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
sounds like you may NOT have the wiring correct, there should be a bypass wire [starter to ignition sw to coil OR output end of resistor] that's only 'hot' when the starter is engaged, and a 2nd hot wire to the ignition switch that feeds the input end of the resistor when the key is on [brown wire here] - the symptoms say you're missing that 2nd connection somewhere along the route, the coil fried because it's getting full 12V all the time
i have it wired just like your link shows on the ignition switch, but i don't have the ammeter installed, would that be the missing connection? if so, which wires go to the ammeter?
Indy wink
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
yes, not having an ammeter wired in could be a problem, you should at least have a wire to bypass it, check the wiring diagram
alright, i don't know which combination of wires needed to be hooked up, but it works now grin thanks bill,
Indy wink
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
