7 members (SWEET, Donf, rfs56trk, sron48, 78buckshot, Wickedbass, JW51),
60
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | 54 3100 Where is the brake light switch located under the dash? | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | It's not under the dash. It's on the engine-side of the firewall, but the two mounting screws are inserted from the interior side of the toe panel. See Factory Assembly Manual Sect 12, Sheet 4.05 "VIEW A" 1954 Shop Manual: > p12-37 last paragraph> p12-38 photo and info left column- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | I saw the shop manual but it wasn't as helpful finding the location. Thank you for the help | | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | Does anyone have suggestions on testing the switch? Other than seeing if power is getting to it? I assume if it does then the switch is bad. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Connect the leads of a multi-meter, set on the 20 ohm scale, to the lugs on the switch. In the brakes-not-applied position you should show a "1" on the meter which means an open circuit, no juice flowing. Then move the lever to the "on" position and the gauge should show "0" if it's good. If it still shows a "1" the switch is bad.
| | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Disconnect the 2 leads from the switch,,connect them both together. If your brake lights come on, the switch is bad.,,,,,Very simple. | | |
