4 members (Otto Skorzeny, Bill Hanlon, msmall, Erniegp), 48 guests, and 2 robots.
Topics128,022
Posts1,055,378
Members48,422
#974298 09/25/2013 8:24 AM
54 3100
Where is the brake light switch located under the dash?
DJ __|__
--O-(_)-O--
'54 Chevy 3100
http://imgur.com/5XR6yO3
It's not under the dash. It's on the engine-side of the firewall, but the two mounting screws are inserted from the interior side of the toe panel. See Factory Assembly Manual Sect 12, Sheet 4.05 "VIEW A"
1954 Shop Manual:
> p12-37 last paragraph
> p12-38 photo and info left column
- Lonnie
- Lonnie
My '54 3104
FPMnky #974332 09/25/2013 10:34 AM
I saw the shop manual but it wasn't as helpful finding the location. Thank you for the help
DJ __|__
--O-(_)-O--
'54 Chevy 3100
Does anyone have suggestions on testing the switch? Other than seeing if power is getting to it? I assume if it does then the switch is bad.
DJ __|__
--O-(_)-O--
'54 Chevy 3100
Ex Hall Monitor
Ex Hall Monitor
Connect the leads of a multi-meter, set on the 20 ohm scale, to the lugs on the switch. In the brakes-not-applied position you should show a "1" on the meter which means an open circuit, no juice flowing. Then move the lever to the "on" position and the gauge should show "0" if it's good. If it still shows a "1" the switch is bad.
Tiny #974390 09/25/2013 4:00 PM
Thank you for the help!
DJ __|__
--O-(_)-O--
'54 Chevy 3100
FPMnky #974467 09/25/2013 11:07 PM
Disconnect the 2 leads from the switch,,connect them both together. If your brake lights come on, the switch is bad.,,,,,Very simple.
