| | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 54 | Hi - just wondering if my park lights should be on in both positions of the light switch. They come on now if I pull the switch to the first position, but are off when I pull the switch all the way to headlights. I have a 37 gmc 1/2 ton. I woulda thought you'd want the park light/running lights on in both modes - when the headlights are on, presumably it's dark out and you'd want to be seen from behind as well. Anyways, let me know if you know. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | parking lights are the front small lights, only on in the 'park' position of the switch - running lights are a more recent concept, if you prefer to have running lights [parking lights on with headlights], there's a tech tip for that - tail lights should be on in both positions, if your tail lights go off when you switch on headlights, you have a wiring problem
Bill | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Park lights do not illuminate when the headlights are illuminated. Does your '37 have tail light(s)? It should illuminate when either the headlights or park lights are illuminated. > Recent park light thread- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I recently adapted turn signals on my 49 3100 and use the front parking lights for turn signals & still maintain the standard parking light feature. IMHO when I'm running w/the headlights on, I like the idea of the parking lights being off as it seems to make the flashing parking lights more noticable when using the turn signals. The way traffic is around my way, I definitely want those around me to know when I'm turning and/or brakeing  Dave | | | | | Joined: Sep 2011 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 54 | I have a new harness from Jim Carter and two tail lights. I've also added a dual contact socket in the rears so that I have a brake, and a combined signal and a park/tail. I think i probably have something wired wrong because the tail lights are acting like park lights and are turning off when i put the headlights on. I don't mind the park lights on the front going off when the headlights are on, but I'll have to change my wiring to keep the tail light/park lights on the back on. I just wanted to see if originally the single driver side tail light was supposed to be on all the time and it sounds like it probably was.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Should be a terminal on your headlamp switch for tail, and one for park. Make sure the tails are on the right post. If you want the parks on with the tails make a jumper http://www.stovebolt.com/techtips/electrical/lights/runlites.jpgThe tails should say on with the headlamps | | | | | Joined: Sep 2011 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 54 | Thanks guys - the wiring odyssey continues. | | |
