3 members (Rich'sToys, 54farmtruck, 1 invisible), 96 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,456
#973733 09/23/2013 12:35 AM
che
Offline
does anyone have a pic of a balancer installed on a 235. I pulled mine off and now that I've put it back on it looks odd. I thought the crankshaft would be flush with the outside of the balancer (the side towards the radiator)when pressed on, but I have about one inch from there to the crankshaft. I should have taken a pic before I pulled it off. thanks.
Che
1950 Chevy 3100
How do your three pulleys line up?
1951 1 Ton Completed
This is the best I have. Hope it helps.
Click
Bruce
My Trucks
Stuff I Collect
Mine is the same (58 235, high mount water pump with adapter plate) the nose of the crank does not do all the way flush with the balancer.
Look at the bore of your balancer... you should see a line were the rust stops and the nose of the crank starts... its about half way.
When you have the balancer properly installed (pulley to the rear) as long as the water pump and crank pulley's line up... that's as far as you need to go.
Tapping the crank for a bolt to keep the balancer on is popular option. There is also a tool a guy here made to make it as easy as possible.
