0 members (),
146
Mod | | | Forums66 Topics128,162 Posts1,056,939 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2013 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 59 | Brand name is Chassis parts Part store is Advance Tie rod end closest to the tire
Tie Rod Ends from advance auto Part Number is DW-ES350L I got home and checked them beside my old ones and the new ones seem too long.I called back at advance and the guy swears it's the right part.I need the one that's closest to tire and I have a 65 SWB step side.can someone tell me which part number I need from advance, O'Reilly,s or AutoZone I would greatly appreciate it.I'm planning on putting them on tomorrow if I can find them. T | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Anti-Ricer, the Moog p/n for the outer tie rod ends is ES350L, the inner tie rod ends p/n is ES370R, any automotive parts store should be able to cross them over to their p/ns, hope that helps. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | When you say it is "too long", where does it seem to be longer? It's not unusual to see aftermarket tie rod ends with longer threaded sections, which allows for more alignment adjustment, and more thread engagement in the sleeve, making the assembly stronger.
Bill Burmeister | | |
