Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (Hotrod Lincoln), 195 guests, and 2 robots.
Topics128,290
Posts1,058,566
Members48,492
Can anyone with a 3600 tell me the proper location of the spacer on the spring hanger. Mine came apart with the spacer on the outside of the spring but the manual says the inside of the spring??? Manual must be wrong because of alignment with the rear axel perch.
Just re-arched, painted and hung the rear springs on my 54 3600. The spacer is definitely on the outside. The alignment with the spring perches is off significantly otherwise as you have stated.
Would have to dig deep into the rebuild archives for pics but i am fairly sure that before i pulled the springs of to restore them the spacer was on the outside as well (the truck was stock and untouched at that time). Hope this helps. If need pictures i can probably dig some up.
Chooglin
1954 3600
[/url] www.tors54.tumblr.com
