Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Woodcmiami, Peggy M, Southerntruck), 117 guests, and 6 robots.
Topics128,282
Posts1,058,496
Members48,490
#97348 09/28/2006 4:26 PM
Hi Guys I'm back, In my last post titled "Alternator Won't Charge" I asked for help installing the alternator on a 55.1st series P/U. Well its in now but I have another problem and would like your advise. There is a small pull on the battery. When I remove the ground strap and use my test light in series between the strap and the ground post I can light the light (something is grounded). If I remove the wires from the alternator the light goes out. My question is: Is there a short in this alternator? Thanks in advance for any advise you can send my way.
Tony
#97349 09/28/2006 5:18 PM
Sounds like a draw to me tony. If you remove the battery (big) wire from the alt. by itself do you loose the draw? If so sounds like the alt. is the problem. But double check and make sure that the Big wire off the alt. dosn't go to anything else. Also check to make sure you hooked up the other 2 wires correctly. I know that it has been posted that you can hook up your alt. bypassing the key switch, if you do you can have an alternator that stays ennergized with the key off or have an engine that wont turn off.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
#97350 09/28/2006 5:45 PM
Its going thru the key switch and the ampmeter but the draw is gone after the heavy wire is removed from the alt. I should think that if the ign switch or the ampmeter were shorted the draw would still be there as the ground source would still be there. But am I correct in my thinking that there should be no continuity to gound thru the alternator?
#97351 09/28/2006 6:31 PM
Yes that is a correct assumption as long as the alternator is properly wired.
#97352 09/28/2006 10:42 PM
Riding in the Passing Lane
You have a bad diode in the alt. If you like to fix things youself you can check it & replace it yourself. Diodes pass current only one way. If you hook an ohm meter or self powered test light to each one you should get continuity one way & reverse the polarity & get no continuity.
1972 Chevy c10 Cheyenne Super
#97353 09/28/2006 11:27 PM
Thanks, I think I know how to troubleshoot some of the stuff but more times than not I just get into trouble. When I get a chance to bounce the ideas off someone with knowledge of the equipment it really helps. I'll let you know how it goes.
Tony
