1 members (baldeagle),
40
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Hello all, I bought a new 46 1.5 from a friend in Dodge city, KS this past Wednesday. After checking the block number I can't seem to identify it through all the normal routes. After using a little "Purple Power", the Block # shows S52018KAN. Thinking I made a mistake, I looked at the title and the exact same number is listed for the VIN. Any help will be appreciated. I found my other 235's under our tech tips with no problem, however this time I'm stumped. | | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | The title does have it listed as a 1945, does anyone know of a source for war time engine codes? Ok, I mean engine serial number codes by year.
| | | | | Joined: Sep 2013 Posts: 2 New Guy | | New Guy Joined: Sep 2013 Posts: 2 | Inliners has an extensive list of Chevy block casting numbers. Their list helped me confirm my 1947 235 that was in my 1949 1 1/2 ton.
Toolman 1949 Chevy 4400 1 1/2 Ton Pickup | | | | | Joined: Sep 2013 Posts: 52 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 52 | I was able to determine that by the block number, my 235 is from 1955-57.(3837004) However, what is stamped on the pad behind the distributor is confusing. Here is a pic: http://s36.photobucket.com/user/riverwork/media/Chevy49/Ser/Serial.jpg.htmlReads across the top:MRC45439, then the line below is:031559Z F56Z | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | http://chevy.oldcarmanualproject.com/chevyresto/56009.htm0315592 - 1000 = 314592 = sequence/unit number F = Flint, MI engine plant 56 = 1956 Z = 6 cylinder (235) car engine What are the head and block date casting codes? That code on the top might indicate it was a replacement engine. | | | | | Joined: Sep 2013 Posts: 52 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 52 | Block is 3837004 Head is 3836848 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Those are the block casting code and the head casting code. Both were used over more than one year.
The date casting codes tell you when the block was cast and when the head was cast. Their locations are shown at the link I posted above.
| | | | | Joined: Sep 2013 Posts: 52 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 52 | Hi Tim,
I'll have to get the head date codes tomorrow, but for the block I've got 00N4. C126. ....March 12, 1956? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes - 1956
That code above the engine serial number is interesting: MRC45439
Maybe someone has an idea for what it is/means.
Since the engine is a car engine, that code might be a DMV code for a replacement engine?
| | | | | Joined: Sep 2013 Posts: 52 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 52 | Tim,
On the distributor side of the engine I see this on the head: 913 and below that, B 48
The number one above looks a little like a slash.
If this is a 56 passenger car engine, does it have hydraulic lifers? ..and regardless, what year/model should I use for tune up specs (timing, valves, etc.) | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | My two cents on your numbers are this... I think the 92 at the end of 0315592 was added. The factory number looks like 03155 F56Z, making it the 2,155th "Z" engine made in Flint in 1956. I agree with Tim, the MRC number is more than likely a remanufactures serial number and the 92 could be the year it was done. Mike B  | | |
