5 members (Gdads51, Otto Skorzeny, jay d, Hotrod Lincoln, ‘37ChevyPU), 173 guests, and 0 robots.
Topics128,109
Posts1,056,262
Members48,439
Eventually, I want to get a COE and put it to use in my construction company for small loads of lumber and perhaps mulch or soil. I live in a pretty urban area and could use a smaller not a larger truck. The COEs are eye-catching and very cool in my opinion.
Was there a smaller COE made that I might start looking for that was made with a dump?
Bob
1954 Chevy 3100 5-Window
1954 5-Window COE aka "THE BEAST"
Bill Ritchie's Original Truck
Granddad's Hardware Store: Ritchie Hardware, Concord, N.C.
Bethesda, MD
The dump bed would be an aftermarket item. So you're probably looking for a short wheel base COE with or without dump bed and you could add the bed of your choice.
•1952 Chevrolet 3800 pickup
---All pictures---
Camp Commandant
Camp Commandant
I believe that a 1 1/2 ton is the smallest GVW wise. I don't have my books handy but I know there were several wheel base lengths offered.
Here one from a fellow bolter, which I believe may be a 2 1/2 ton but it gives you an idea.
http://www.stovebolt.com/gallery/mueller_brian_1946.html
I'm sure you could find a vintage looking dump bed to put on a a cab and chassis.
I look forward to seeing pull into TW Perry's for a load of lumber!
~ Billy
1959 GMC 860 | Pictures
Seeing how you already have a '54 Chevy 3100 series, i'm guessing you want a '47-'54 model COE to match it. If that's the case, a 110"in. wheelbase 5100 series 2 ton COE is what you're looking for. There were a few 1 1/2 ton special order 15000lb. gvw 1 1/2 tonners, but you don't find them often. Chevrolet COE's from that era came in three wheelbases, 110"in. 5100 series, 134"in. 5400 series, & 158"in. 5700 series. Stovebolt member GeoRichards, has what I believe you're talking about, http://s1054.photobucket.com/user/GeoRichards/library/?sort=38page=1
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
The fact that regardless of GVW all the 1 1/2 to 2 1/2 COE. trucks discussed hear are pretty much the same size with exception of their wheel base and loads typically hauled on a dump truck go heaviest short wheel base truck you can find. Remember 1 yard of gravel weighs close to a ton and a half then you have the weight of the dump body its self.
A five yard load on my 64 GMC 6000 puts my scale weight at 23000 lbs.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
That's what I want. GeoRichards and Brian Mueller have exactly what I am after. If you two ever want to sell, let me know, but probably a ways off.
Otherwise I'll start looking. They have to be out there somewhere.
Thanks!
Bob
Bethesda, MD
That '46 is actually not a 5 ton. Chevrolet had no truck COE, or Conventional rated higher than 16000 lb. gvw 2 ton. 1946 was the first year for a 2 ton rating. Everything civilian Chevrolet before 1946 was rated no higher than 1 1/2 ton. 1956 was the first year for a Chevrolet truck rated at 2 1/2 ton. GMC however, had trucks from 1/2 ton, all the way up to 20 ton.
Spanky Hardy
1950 GMC 250 1-Ton
