1 members (baldeagle), 54 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#973331 09/21/2013 1:41 PM
Hello all, I bought a new 46 1.5 from a friend in Dodge city, KS this past Wednesday. After checking the block number I can't seem to identify it through all the normal routes. After using a little "Purple Power", the Block # shows S52018KAN. Thinking I made a mistake, I looked at the title and the exact same number is listed for the VIN. Any help will be appreciated. I found my other 235's under our tech tips with no problem, however this time I'm stumped.
The title does have it listed as a 1945, does anyone know of a source for war time engine codes?
Ok, I mean engine serial number codes by year.
That KAN at the end might be an indicator that you have a replacement engine (KAN for Kansas).
Post the block & head casting codes, and the block and head date codes. Those will give useful ID information.
Inliners has an extensive list of Chevy block casting numbers. Their list helped me confirm my 1947 235 that was in my 1949 1 1/2 ton.
Toolman
1949 Chevy 4400 1 1/2 Ton Pickup
I was able to determine that by the block number, my 235 is from 1955-57.(3837004) However, what is stamped on the pad behind the distributor is confusing.
Here is a pic:
http://s36.photobucket.com/user/riverwork/media/Chevy49/Ser/Serial.jpg.html
Reads across the top:MRC45439, then the line below is:031559Z F56Z
http://chevy.oldcarmanualproject.com/chevyresto/56009.htm
0315592 - 1000 = 314592 = sequence/unit number
F = Flint, MI engine plant
56 = 1956
Z = 6 cylinder (235) car engine
What are the head and block date casting codes?
That code on the top might indicate it was a replacement engine.
Block is 3837004 Head is 3836848
Those are the block casting code and the head casting code. Both were used over more than one year.
The date casting codes tell you when the block was cast and when the head was cast. Their locations are shown at the link I posted above.
Hi Tim,
I'll have to get the head date codes tomorrow, but for the block I've got
00N4. C126. ....March 12, 1956?
Yes - 1956
That code above the engine serial number is interesting: MRC45439
Maybe someone has an idea for what it is/means.
Since the engine is a car engine, that code might be a DMV code for a replacement engine?
Tim,
On the distributor side of the engine I see this on the head: 913 and below that, B 48
The number one above looks a little like a slash.
If this is a 56 passenger car engine, does it have hydraulic lifers? ..and regardless, what year/model should I use for tune up specs (timing, valves, etc.)
My two cents on your numbers are this...
I think the 92 at the end of 0315592 was added. The factory number looks like 03155 F56Z, making it the 2,155th "Z" engine made in Flint in 1956.
I agree with Tim, the MRC number is more than likely a remanufactures serial number and the 92 could be the year it was done.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
