4 members (Gdads51, Shaffer's1950, BarryP, Robert Crandall), 79 guests, and 1 robot.
Topics128,150
Posts1,056,985
Members48,460
hey all
i have a 261 with a fenton intake and 2 carter2100 carbs with manual chokes.
how does one go about hooking up the chokes?
there is the little brass blocks to screw in the wire, but no mounting fr the cable housing.
also i have 2 carbs and 1 choke cable.
how have folks set up this configuration in the past?
i cant find any pics
thanks in advance
jay
these are carter yf2100 carbs, not the yf2100s
You'll need to have the parts that hold the cable, which are separate from the carb itself. They do not necessarily have to be from a Carter, the one from a Rochester will work. See Fig. 2, the part I'm talking about is on the right side of the picture.
With duals, you only need to hook up one choke, that will be plenty to allow for starting.
Bill Burmeister
