2 members (Guitplayer, 1 invisible),
174
Mod | | | Forums66 Topics128,196 Posts1,057,395 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 96 | Would the 6.9 or 7.2 diesel used in the F250 be to heavy for a 51 3600 front end as in would it be any harder to fit then the normal 350 or 351? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Try a 12 valve cummins. All mechanical. It's like the back to the future car. Thing could run on garbage. Bullet proof engine. I believe they are heavy though. Minimal fuel plate adjustment and you double the torque and hp and are still reliable.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The 4BT Cummins fits a lot easier in an AD truck than the very long 6 cylinder Cummins.
As for the indirect injection V8 fords, they're nothing special these days, may not be as nice a swap as something a little more modern. Not sure on the size and actually fitting one... I bet it's very tight. The front axle will be very well loaded, perhaps overloaded.
Grigg | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Why in the world do you want to put a Ferd engine in a Chevy? Sounds like a lot of work just to prove it can be done.
| | | | | Joined: Feb 2012 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 96 | Kind of what I though on the heavy side. Just happen to have a 7.2 turbo diesel out of one that is being junked. It is an International engine Ford just uses it. The Cummings I know is way to heavy. Keep in mind the 3600 isn't much heavier then the 1/2 tons. It still has a running 216 in it right now.
| | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | The cummins weighs about 1100 the ford is close to 1300. Both are a lot of weight. The front axle needs to be beefy either way.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | 4BT is not that heavy, comparable to the Stovebolt. | | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | The 4BT is probably going to be in the 700 to 800 lb range ready to run. That's not too bad all things considered. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I think it's a cool idea. The IH/Ford powerplant is probably a mule of an engine. Slightly on the heavy side. Some updated front springs would definately be in order. Not to mention the steering box will more than likely need to be relocated.
If you're going for that dare to be different category, why not look into a GM 6.2/6.5? They're plentiful and use big-block motor mounts. | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Naturally aspirated? Weren't those gutless? My buddy had a diesel suburban that couldn't get out of its own way.
| | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | Yeah, they were a little sluggish until ferd turbo charged them. | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | I don't want to jack the thread but the 7.3 is a good motor. Not as good as a cummins but its good. Duramax doesn't last..
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If it were me and having some idea just how much trouble (lots) it'd be to install a 7.3 in an AD truck it better be a whole lot better than simply a "good motor" to make it a worthwhile project. I'd be looking for the best engine I could find with little or only reasonable difficulty to install.
The 4-53T I have in my truck is a great engine, I like it and understand it, but it is just a little longer than fits comfortably in an AD truck. My next swap will be a 3-53T in another Ad truck, that'll be a lot simpler with one cylinder shorter.
Grigg | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | Just got back from Field Day of the Past in Rockville Va. Talked to and checked out his truck, 47 Ferd with powerstroke. He is retired from Westerbranch diesel and when asked why all he said is "What does a retired diesel mechanic do in his spare time".Larry
58 gmc 100 with 350 sbc
