3 members (Nick in Manitou, Wally / Montana, 1 invisible), 58 guests, and 3 robots.
Topics128,076
Posts1,055,920
Members48,429
So... I let a friend borrow my 1965 1-ton GMC dually (305V6) since his truck was getting worked on.
He called me yesterday just about crying, ran the oil out of it.
So... I guess I will stuff a SBC/700R I have into it.
I know I could dig around and find the info, but this site is so jammed full of experienced experts that I'll ask:
Motor mounts and trans crossmember for this swap available?
Thanks!
Brewtus
1952 Chevy COE 5-Window, 1948 COE
More pix in the 'Bucket
Use to have --'50 panel, '50, '49, '54, '51 1/2-tons.
'67 Corvette for those 'need for speed' times
Earlyclassicenterprises has the cross member for the trans. I was looking yesterday. The rest should be cake.
Wait... bolters don't cry! Use it as an excuse to make it better. I like your idea of a SBC/700.
I'm sure other's here will chime in with your answers. Seems pretty straight forward.
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
Thanks, Hollow. I'm in SD a lot, one buddy in LaJolla, the other in Santee.
Brewtus
Chevy stuff(mounts,xmembers) up to 87 or so will bolt in.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
DMG, he was crying because he knows he pulled a bonehead move and hurt my truck... I won't make him pay for anything, but will urge him to help with labor.
I'm assuming there are some factory motor mounts, I'm still snooping around in between clients.
Brewtus
I got a 502 at ricks machine in santee by the drive in. Throw that in your truck. It made 612 hp and 580ft-lbs. a buddy of mine bought it, had it gone through and never picked it up. Might still be there lol
I'm in St. Louis, Hollow, I think the shipping costs would be more than the value of my truck. wink But it would be fun to surprise Mustangs in a 1-ton dually.
Brewtus
Yeah it would. Take care and good luck.
brewmeister
I put a 350/700R4 in my 64.
I originally had a 6 cyl and manual trans.
My original trans crossmount had to come out and I had to pick up some V8 engine mount brackets.
You will have to shorten the drive shaft and mount a new trans crossmember for the 700R4.
Don't forget to wire in the overdrive through your brake system.
Also don't forget the radiator will need to be a bit bigger
All and all not a hard swap.
The wild card in the deck is that mine was a 1/2 ton and you are talking about a 1 ton truck. And that I don't know about.
Do you have any issues with the 700? I heard some people gripe about the o.d. Going out. I've looked at o.d. Trans for my truck but they're like 4-5k. That's about a 1/3 of the total cost of my entire build. Not worth it. Good luck brew.
Thanks Rusty! I'm new to the 'bigger' trucks so I'm not sure but I think the frame rails are the same as the 1/2-ton, so should be the same as what you did in terms of the swap.
If you are in St. Peters maybe you can be my coach, lol...
Brewtus
Hollow, I know guys running them (700R's) in different configurations and so far I've not heard complaints.
Craigslist here is full of them for anywhere from $100-$400 or so.
Brewtus
I do have a spare stock rear a/t rear crossmemeber from a 66 3/4 t if you are looking for orig
ron
http://imageshack.us/a/img13/3072/img00237201206250745.jpg
http://imageshack.us/a/img39/7137/img00238201206250745.jpg
The 700 is a great transmission, however, it may be a bit light for a 1 ton truck that's still getting used as a truck. GM didn't use them in anything bigger than the light duty 3/4 ton. There is another option, though; The 4L80E. That one is more or less a TH400 with an overdrive. It was used in 3/4 ton HD models, as well as 1 ton trucks. If you don't mind doing the setup for the PCM, you may consider looking for a decent used 6.2/4L80 combo from a late model truck. Just make sure to get everything that goes with it.
Bill Burmeister
I installed a stock SB350 with a 700R4 in my 1941 1Ton 6,000 miles ago with no problems. With the proper after market mounts and a larger radiator it was a simple job and I am very happy.
I have a 3.73 rear end pushing 7.50X17 tires so I get 70 mph at 2,000 rpm.
A nice modern drivetrain is a nice idea. You can get harnesses to work with it. My brother Did an 88 s-10 with a z06 drivetrain. The harness came as a kit. I think it was a painless conversion kit. It wasn't cheap but it was clean and easy to figure out.
Moderated
Moderated
ron
padresag, If brewmeister doesn't have any interest in that crossmember, I might be interested. I have my own unplanned engine and tranny replacement happening. Not sure about it yet, though.
