| | | Forums66 Topics128,118 Posts1,056,646 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | I installed my new 6v heater blower switch yesterday. it works great, however upon turning it on it started to smoke as long as I ran it. After about 10 minutes I feel the smoke was decreased by 50% or so, but I am wondering if anyone else has experienced this? Maybe some oil is applied to some of the internal parts and it just has to 'cook off'? Also my original switch only ran on one speed out of three. Upon removal I found it is supposed to have a glass fuse, any idea what size fuse this takes? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | The picture is too small to see anything. The switch gets hot by it's design so if there's any oil or other material on the coil it'll burn off. That may be the smoke you refer to. The lower you set the speed the hotter it gets because it's dumping the electricity not sent to the fan motor to the coil to be expelled as heat. Turn it on and watch closely to make sure nothing catches on fire & see if the smoking stops after a bit.
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Also my original [air] switch only ran on one speed out of three. Upon removal I found it is supposed to have a glass fuse, any idea what size fuse this takes? Curt - Brad Allen is the resident expert on heaters and switches. If he doesn't see your post, drop him a PM. Betcha he will know and probably have a NOS switch in-the-box that he can check. - Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | Thanks Tiny, and Lonnie. Brad and I live in Salt Lake City, and He has helped me before, I will send him a PM.
| | | | | Joined: Jun 2010 Posts: 170 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 170 | This may not be related - but check to see that you don't have any plastic wire insulation touching the metal on the switch. I had smoke under my dash and thought a switch was bad, turns out I had used one of those crimp on connectors and had bent it by accident. The plastic touched metal, melted and caused smoke. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I was unable to buy a new switch that would stand up to the current of my 6 volt heater motor. I had two new ones melt when on reduced speed. The one I have now I use as an off and on switch. I don't go past the first click and thus the resistor element is not used. | | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | Dave46pu I did not even think about the plastic crimp connectors that I used! I have since removed the plastic sheath but my smoke is coming from inside the unit. The smoke is definitely subsiding,so hopefully it will be gone soon. I hope the unit does not burn up like truckernix did! | | | | | Joined: Jun 2012 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 85 | Man that light is bright, I mean like hot-bright! Is the knob hot? Sure the correct bulb is in that switch?
Mike
| | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | New switches are usually coated with a protective film to keep the rust gods at bay. Looking at the light in your picture, it is bright, but not sure if that's the camera or not?
Let us know what Brad has to say | | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | I forgot to follow this back up. Brad felt a 10 or 15 amp 6V fuse is what the switch I removed would take. | | |
