3 members (Hotrod Lincoln, Ponchogl, 1 invisible), 40 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#972402 09/18/2013 1:54 AM
I'm about to mount the radiator and frame on my 41. I have the needed pads but no bolts or springs What do you guys recommend for this application? Should I use carriage bolts? What springs are recommended and how tight do I tighten them up?
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
i am not real sure on the factory bolts on your truck..but i have used carriage bolts on them, even tack welded them down to a plate as insurance the wont spin.. i drill a hole near the end for a cotter key and use castle nuts.. springs may be a little hard to come up with the proper ones. i have used old valve springs from briggs and stranton motors before
if you cant run with the big dogs...then stay on the porch
http://s202.photobucket.com/user/rcplumley/library/
