Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (DennisM, Petrolhead 69), 107 guests, and 2 robots.
Topics128,277
Posts1,058,453
Members48,490
Hello all.
Well it's time to consider the dash. I have a '54 all converted to 12 volt and I am wanting to know if there is a way to use the original gauges? If there is not, does anyone have a recomendation on a cluster that still retains the old "look". As always, THANKS
All the best, Ted
TEDS 54 PANEL,
You can use all your stock gauges, or buy new shiny ones.
The only gauge that is actually voltage sensitive is the fuel gauge. A simple, inexpensive voltage reducer can make your stock one work perfectly.
You can buy completely new modules from many of the vendors if you choose to.
The sky is the limit, but they can all look perfectly STOCK if that's what you want.
Stuart
What Stuart said.
haneline
http://www.haneline.com/home.html
they have a new 3 in one 5'' for our trucks ....
Ps
stu's right
get rid of the amp gauge and go voltmeter, which will require a little different wiring, and probably easier too. you can reface them too.
Jim & Caroline
Quote
As Stuart said, if you want to keep as many gauges as possible (and keep them looking the same) you can by a $15 Runtz voltage reducer for the fuel gauge (or buy a 12v original-looking fuel gauge from one of the repo parts vendors).
No need to do anything with any other gauge - they will all work fine.
Hey Carolines Truck;
how do you like the Haneline Gauges? The 3 in 1 is pretty cool looking. What color did you choose?
