2 members (Hugh63c10, Peggy M),
146
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,193 Posts1,057,360 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 59 | I am need at this I want to remove the front window from my 1965 GMC truck as I need to repaint the inside of the cab and do other work on the inside I have the cab off the frame sitting in my shop
Bob May
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | really the only way is to cut away the outside face of the weatherstrip with a very shape knife and replace it with a new rubber when ready to re-install
Bill | | | | | Joined: Oct 2012 Posts: 57 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 57 | if it is the old windshield gasket it is best to get a new gasket.. so just take a razor knife and cut the old seal next to the glass toward the body from the outside to get the windshield out.. if it is a new seal i have worked slowly and lifted the seal from the body flange while pushing out from the interior side..but very very very much caution and soapy water must be used and dont get in a hurry.. but maybe someone else knows a better way | | | | | Joined: Nov 2001 Posts: 1,522 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,522 | With a sharp utility knife, cut the rubber around the windshield. Have a friend help you lay the windshield out and store it. Use a new STEELE Co. rubber gasket when you reinstall it. | | | | | Joined: Aug 2013 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 59 | delux54panel you said to use new gasket from STEEL Co. do you have their E-Mail address or how to order a catalog form them
Bob May
| | | | | Joined: Apr 2013 Posts: 33 New Guy | | New Guy Joined: Apr 2013 Posts: 33 | Be aware that if your windshield has the chrome trim installed in the rubber, reinstalling it will be a major ordeal. I just had it done a few days ago and I'm glad I wasn't the one doing it. It took two guys two hours. The installer said that curved windshields with trim in the rubber were a nightmare to install. I'm using a gasket from LMC and it seems to be ok. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Removing the windshield, is best achieved, as referenced above.
The '64-'66 Chevy/GMC truck windshields, with the stainless steel trim, is a bit challenging, but not too tough, with the right approach. Put the stainless in the rubber, put the rubber on the windshield & put the assembly in the hole.
