1 members (Erniegp), 47 guests, and 3 robots.
Topics128,055
Posts1,055,782
dang
Recently purchased on the eBay I had a "DOH" moment and purchased a voltage regulator that turns out to be for a 1960s GM alternator. It was early in the morning and I was not fully awake. It looks just like a regulator that is for a generator system. The 3 terminals, left to right, are marked Bat, Arm, Fld.
Can a voltage regulator stated for an alternator system work on a generator system?
Your comments will be appreciated
Walt Williams
La Verkin, UT
any alternator regulator I've seen is different in appearance, connection and function from a generator regulator .... a number on it might clarify the application ... or you could just try it and see, being you probably can't return it wink
Riding in the Passing Lane
You cannot enterchange them. The gen. reg. is rectangular in shape & has 3 screw terms. The alt. reg. is rectangular & has a plug in term set with 4 blades.
1972 Chevy c10 Cheyenne Super
" Wiring instructions for the early GM Delco Remy external regulated alternator. How to wire an external voltage regulator on a GM vehicle. The early GM alternator is the 10DN series alternator and was used on GM vehicles from about 1963-1970"
As Bill posted, it looks different and has different leads/wiring.
What is that converter (12v to 6v; and other 2v to Xv) in the second link for, Bill? They look interesting.
Here is a couple of photos of the regulator in question:
Regulator photo 1
Regulator photo 2
I am betting this is really a generator regulator in spite the fact they advertised it a an alternator regulator.
If it a generator regulator any reason why I couldn't use it with the 1955 or later generator on my 54 3100?
I acquires 55 and later part to convert to 12 volt.
Walt Williams
La Verkin, UT
scroll down here, that doesn't look like an alt reg, they have 4 connections and says applies to 56-59 GMC
Tim, those 'converter' items appear to limit a 12V alt to 6 or 8V - I had a local shop convert a 12V internal regulated alt to 6V, and he just installed something like that inside to replace the internal regulator
No chance it will work.
A generator works by passing wires through an PERMANENT magnetic field, the generator has magnets bolted inside the case. A generator regulator for the most part controls the flow that comes out of the generator.
An alternator works by passing a wires through an ELECTROMAGNETIC field, its regulator controls the electromagnet.
Two completely different birds.
Mikey
1951 Chevy 3600 rust bucket with GarWood dump bed conversion
http://www.flickr.com/photos/mikeybs51chevy
yes Mike, no chance it would work if it was for an alternator, but it's not, it's for a generator
