4 members (1955 1 Series, Barney1951, Otto Skorzeny, 1 invisible), 44 guests, and 2 robots.
Topics128,032
Posts1,055,438
Members48,422
#970208 09/08/2013 8:26 PM
Okey dokey.
Got my starter and generator rebuilt. Which appears to fixed my charging problem. Now I noticed the fuel pump is leaking. It appears the diaphragm is no good. So, do all fuel pumps for the 235 engines fit all 235 engines? When I look them up there are lots of numbers.
I believe I have a 57 car 235 engine. The number behind the distrbutor is FI223A or F1223A.
Dennis
oldbluetruck #970244 09/08/2013 10:01 PM
I'd use a fuel pump for a 1948 truck. That might get you a pump with inlet and outlet holes at angles that will match the angles of your tubing.
oldbluetruck #970312 09/09/2013 9:29 AM
I just addressed this issue on my '55.1.
The original truck fuel pump on the '55 235 has the metal cap (no glass globe) and the fuel line runs parallel to the engine block. GM subsequently modified this pump to accomdate the engine mounts on the later cars, requiring that the fuel line be off-set by 20 degrees (the input line angled away from the block and the input line angled towards the block). The engine mount in the '57 car required this.
On my truck, the PO had replaced the original pump with the later pump with the off-set. So either one would work, but I chose to go back to the original setup and adjusted the fuel lines without much trouble.
If you want the pump with the off-set, they are widely available and fit all of the 235's. Classic Parts has it and so does Napa. If you want the pump without the offset, Jim Carter has them. Note that the various listings do not clearly distinguish this, and in later years GM sold the pump with the off-set for all applications, including the earlier trucks that did not need them.
I used Jim Carter's pump. Went in easy and works great on my 55.1!
If you don't care which pump your truck originally came with, just match the one that's in there (likely the one with the off-set) and avoid fiddling with adjusting the fuel lines.
Trooper Jeff
If I can't drive my truck, fetch my horse
"Courage is saddling up even though you are scared to death" - John Wayne
oldbluetruck #971389 09/13/2013 11:09 AM
I assume any fuel pump for a 216 or 235 will work on either engine.
Dennis
oldbluetruck #971399 09/13/2013 11:35 AM
216 and 235 pumps both mount the same. The main difference is the in and out fitting positions.
My Blog
oldbluetruck #971401 09/13/2013 11:36 AM
Thank you
Dennis
oldbluetruck #971503 09/13/2013 9:23 PM
hey Dennis, here is a deal for you
take care of all of your problems...
Redryder pix
My Hotrod
oldbluetruck #971594 09/14/2013 10:55 AM
Thanks Fred.
Dennis
oldbluetruck #994997 12/27/2013 1:12 PM
I know this post is a little old but my fuel pump is leaking (1955 first series). Jim carter sells a glass bowl fuel pump that fits 37 to 62 but the other suppliers seem to make a distinction between 47-51 and 52-57. I am always leery of buying anything that fits a lot of years but this Jim Carter pump is on its way. Does anyone know what changed in 51/52? I suppose if its just an exit angle of the gas line I will be OK.
From the Jim Carter catalog...
"Fuel Pump 1937-1962 Chevrolet and 1939-1959 GMC 6 Cylinder Glass Top Type
Item Number: ME737"
1955 First Series 3100
oldbluetruck #995000 12/27/2013 2:03 PM
I found a post from Lonnie, it looks like 51/52 was the change to the angled ports.
Joe
