2 members (Otto Skorzeny, Nick in Manitou), 113 guests, and 2 robots.
Topics128,031
Posts1,055,436
Members48,422
#971490 09/13/2013 8:29 PM
I need to replace the fuel line between the fuel pump and carb. Is aluminum line with compression fittings acceptable?
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
jmoore #971492 09/13/2013 8:36 PM
I would check to see what length you need and see if the local parts store has a steel line near that length. Then bend your own. I have never been a big fan of compression fittings. The lines from the parts store will have double flared fittings on it already.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
jmoore #971493 09/13/2013 8:37 PM
Steel line with double flare fittings would be better, and is what was used OEM.
Bill Burmeister
