3 members (WICruiser, 2 invisible),
142
Mod | | | Forums66 Topics128,109 Posts1,056,269 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 39 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 39 | Hello fellas, I need some advice on what battery charger I should buy. I figure that there are plenty of you who have tried different types and could give me a heads up. I moved a couple of years ago and had to store my 36 in my old garage. I try to go and start it up and drive it a few blocks every few months but last time the battery went dead. It's a fairly new battery. I need to go and get something out of the garage soon and guess what will be blocking it? Thanks for any info. Cheers Christian | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Christian, I have used 6v/12v battery chargers from Harbor Freight for many years. Unfortunately the 12v side is automatic but the 6v side is not. You might want to buy a 6v float charger to keep the battery charged? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I use a Schumacher float charger. It's automatic 12/6v. If you connect it to a 6v battery it'll automatically switch to a 6v maintenance cycle.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
Denny G Sandwich, IL
| | | | | Joined: Jun 2012 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 85 | I have been using a "Battery Tender" for years, small, it works great, doesn't boil the fluid out, keeps it charged. Comes with a quick connector and 2 pigtails, one to hard wire, the other big alligator clips. I hardwired to easy to connect/disconnect without going to battery. When I need to charge something else connect the clips. $25 at Amazon for 6V http://www.amazon.com/Battery-Tender-021-0127-Junior-Charger/dp/B000CIPHT4Mike | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Just posted that cuz Tiny mentioned Schumacher, they appear to be handled by just about everyone out there, 'A' as in Auto Zone was just the first one I picked out of the list. Schumacher is the first one I've seen that makes the claim that it's good for 6v or 12v. I never heard of them before Richard posted their name up. So I guess you dint make it to the reunion this year either??? I was planning on going but things didn't work out as planned, again.
Denny G
