2 members (Wally / Montana, TooMany2count), 32 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#970442 09/09/2013 6:03 PM
what angle are the stock caster shims on 51 3100. i put a 4 inch drop axle on my truck and i think i might need to increase the caster angle because any little dip in the road and it wanders all over. i have my drag link nice and level but im still having a problem. could this be due to no ifs.
johns truck #971139 09/12/2013 10:41 AM
How does it steer around corners? If you need to turn the wheel back manually, then it needs more caster. Mine felt real light at highway speeds, I couldn't hold it straight when it needed more caster. 2 degree is what most start with.
Caster kicks the bottom of the axle forward. Weight over the axle holds it down, the farther out you kick the axle, the harder it is to turn since you have to lift all the weight with the steering box. But, the farther out you kick it, the straighter it will go on its own, think of a front engine dragster, the axle is really leaned back. This also changes the drag link length, and a fixed length drag link will pull the steering box off center. Boxes need to be centered for correct steering. Off center creates odd turning radiuses and no center support steering ( tighter dead center ).
You maybe having bump steer problems. This is where the drag link and axle travel arc's don't line up. If they are off, the axle tends to pull on the drag link on its travels up and down. Since you are holding the steering wheel tight, the only thing the drag link can do is pull on the steering arms and turn the wheels. Thats why its called bump steer, it actually steers going over bumps.
Just having a level drag link is not always the cure. You need to plot out the travel arc of both the axle and steering box. On a large cardboard sheet, measure the axle height, spring hanger height, steering arm height, and drag link height ( mounting point on the pitman arm ). You will also need length from spring mounting bolt to center of axle, and total drag link length, With all these laid out, draw the travel arc of the drag link and springs. You should be able to see the bump steer pretty clear. I forgot you need the distance from the steering arm to the pitman arm. Basically draw out you truck in full size, cut some cardboard patterns, and run it through its travels.
You dropped the axle 4" , Is the steering box still factory mounted? If so the steering box now thinks the truck is fully loaded and squatted down 4". You have used up most of its travel already. GM designed the steering so at normal driving with no load, the truck will drive great, with a heavy load, you are getting at the upper limit of what they think is acceptable. You are way past that just sitting still.
http://www.eatonsprings.com/techquestions/bumpsteer.html
Joe
johns truck #971210 09/12/2013 4:56 PM
i put a power steering box on the outside of the frame. do you know of any pictures that describes what you meant by plotting the travel arc.
johns truck #974015 09/24/2013 9:17 AM
We found out if your running radial tires 4 degree caster shims work great. Napa part number is 264-4107. They are not cheap ($12 to $13ea) sometimes the store makes you buy a box of 6. If need I keep them in stock. Factory only had 2 degree.
johns truck #974019 09/24/2013 9:50 AM
Good thread, great info!
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Drapal #978125 10/12/2013 11:26 AM
how much for a set of these shipped to 29645.
Drapal #978367 10/13/2013 4:51 PM
Does that go for stock as well as a dropped axle? If so I'm going to Napa with that part number. I've been there three times trying to get caster shims for my truck with no luck.
johns truck #980562 10/23/2013 12:34 AM
Update: I know I didn't start this thread but I thought I might offer an update in relation to the use of 4° caster shims (as suggested by Drapal) and its effect on wander and bump steer.
I rebuilt or replaced everything on the front end of my '53 1/2 ton (here) but was still wandering all over the road. Replaceing the original shims with the 4° shims helped out quite a bit. Not a LOT, but still quite a bit. The improvement was well worth the expense
