| | | Forums66 Topics128,283 Posts1,058,518 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 19 New Guy | | New Guy Joined: Sep 2013 Posts: 19 | I have a 41 burb with the no sync 4 speed tranny. Is there a tranny I can swap into this driveline and still keep the torque tube? Jim
'52 GMC, '41 Suburban and '28 Chevy Street Rod
| | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | Not that I've heard of. I've been trying to figure the same thing but all I could come up with is a closed drive SM420 and modify the torque tube and driveshaft. Seems like a lot of work. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The three speed was standard equipment and will fit right in. It is synchronized in second and third.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | I have a 1941 1 Ton Chevy truck transmission with an open drive line.
It is going in my 1946 Suburban that I had a new 3.55 rear end built for.
Think about changing out that old low rear end you probably will sooner or later. Most people do, I have on all 4 Art Deco trucks I have had. | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I wonder how much of a problem it would be to substitute in the newer 48-54 1/2 ton enclosed driveshaft assembly and use the newer 4 speed?
John | | | | | Joined: Sep 2013 Posts: 19 New Guy | | New Guy Joined: Sep 2013 Posts: 19 | The three speed was standard equipment and will fit right in. It is synchronized in second and third. What years am I looking for to find a 3 speed? The same era or is it something newer. Jim
