Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (G508, Guitplayer, sron48, 55shaker, Otto Skorzeny), 112 guests, and 4 robots.
Topics128,283
Posts1,058,518
Members48,490
#971122 09/12/2013 9:06 AM
I have a 41 burb with the no sync 4 speed tranny.
Is there a tranny I can swap into this driveline and still keep the torque tube?
Jim
'52 GMC, '41 Suburban and '28 Chevy Street Rod
I
I Offline
Not that I've heard of. I've been trying to figure the same thing but all I could come up with is a closed drive SM420 and modify the torque tube and driveshaft. Seems like a lot of work.
The three speed was standard equipment and will fit right in.
It is synchronized in second and third.
My Blog
I have a 1941 1 Ton Chevy truck transmission with an open drive line.
It is going in my 1946 Suburban that I had a new 3.55 rear end built for.
Think about changing out that old low rear end you probably will sooner or later. Most people do, I have on all 4 Art Deco trucks I have had.
I wonder how much of a problem it would be to substitute in the newer 48-54 1/2 ton enclosed driveshaft assembly and use the newer 4 speed?
What years am I looking for to find a 3 speed?
The same era or is it something newer.
Jim
