| | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 57 | Could anyone tell me if interior sun visors were available on a 46' Chevrolet 1/2 ton. I have holes in the cab, but no visors. Thanks. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Jim Carter sells the reproductions. I believe it was an option. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | In 1946, the Sun Shade (arm and visor) was available (left or right side) as a factory installed option (Option 261A or 261B) or as an accessory. The visor was laminated plastic material - the color was not specified - brown? 46gmcpu, What is the part number for the JC visor? Here is the visor bracket. | | | | | Joined: Sep 2011 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 57 | Thanks for your help on the visor, I appreciate it. | | | | | Joined: Sep 2011 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 57 | Thanks for your help on the visor. Jim- | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Jim Carter has a newly listed 1946 visor. Item # UPV127 $49.50 EACH I received an email notification from JC today. He had recently added many 1946 parts. They might not be in his on-line catalog but the are available if you know the part number, or maybe if you check the New Inventory link on his website. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Right here he has the visor with the rod Sun Visor With Rod
