| | | Forums66 Topics128,080 Posts1,056,315 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 2 Moderated | | Moderated Joined: Sep 2013 Posts: 2 | I`m new here and say hello to everyone, what I need is the correct way to test the booster, the truck has new wheel cylinders, shoes, and master cylinder and everything was fine, after siting 4 or 5 weeks the booster is not working. Hope I don`t have to replace it. THANK YOU CHUCK41 | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | start the truck with your foot on the brake pedal. when it starts does the pedal slightly drop. if it does then your first test passed. with the pedal dropping it means to me that it is functioning to an extent. that doesnt mean there couldnt be other issues with it. the truck has new wheel cylinders, shoes, and master cylinder and everything was fine define fine | | |
