7 members (baldeagle, Hotrod Lincoln, Bill Hanlon, fonz8261, greenie-reddy, 2 invisible), 367 guests, and 4 robots.
Topics128,162
Posts1,057,068
Members48,463
slide show of bracket rework
This is my progress on upgrading the 1946 MC to a dual chamber. We were in the process of bleeding when the bleeder valve stripped out in the driver's side front wheel cylinder. Once we get a new one to replace it, we should be good to go. The master cylinder is a non power MC for the 67 to 72 chevy trucks drum/drum. It is supposed to have the residual valves built in(I forgot to check inside the ports before it was piped to confirm.) We are going to try it without a proportioning valve to start. If it doesn't work to satisfaction we will add one later. I tried to document everything below the photos but things can be missed. Hopefully this helps others out there.
Oh the truck is using the original drum brakes all the way around.
With a drum/drum set up, you shouldn't need a proportioning valve.
Joe smile
Just a strong leg!
~Jim
X
X Offline
[quote=dsmith] slide show of bracket rework
Does anyone know how to navigate this 'Webshots' site now that they've taken over a previous photo hosting site? When I click on the link, it goes to their main site, not the photo album. I signed up with them and can't for the life of me figure out how to find 'linked' photos. WAJ!
PM me if nec......
Daryl
