1 members (Bucker),
144
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 77 | slide show of bracket rework This is my progress on upgrading the 1946 MC to a dual chamber. We were in the process of bleeding when the bleeder valve stripped out in the driver's side front wheel cylinder. Once we get a new one to replace it, we should be good to go. The master cylinder is a non power MC for the 67 to 72 chevy trucks drum/drum. It is supposed to have the residual valves built in(I forgot to check inside the ports before it was piped to confirm.) We are going to try it without a proportioning valve to start. If it doesn't work to satisfaction we will add one later. I tried to document everything below the photos but things can be missed. Hopefully this helps others out there. Oh the truck is using the original drum brakes all the way around. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | With a drum/drum set up, you shouldn't need a proportioning valve. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
| | | | | Joined: May 2010 Posts: 42 'Bolter | | 'Bolter Joined: May 2010 Posts: 42 | [quote=dsmith] slide show of bracket rework Does anyone know how to navigate this 'Webshots' site now that they've taken over a previous photo hosting site? When I click on the link, it goes to their main site, not the photo album. I signed up with them and can't for the life of me figure out how to find 'linked' photos. WAJ! PM me if nec......
Daryl
