1 members (Cletus1950),
77
Mod | | | Forums66 Topics128,151 Posts1,057,000 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 127 | Ok I need a little help with this weird problem. I just wired in my turn signals and when I pull the light switch out just for parking lamps they come on fine, but the bulb wont flash when I turn on the turn signal. I can hear the flasher working though. Then when I pull the switch out far enough the the head light come on, the parking lamps go out but the turn signals will work. I have the double bulb in for park/turn. So could I have wired the parking lamps up wrong? I did not think that the double bulb would care which side of it goes for turn and what side goes for parking. Any ideas?????????? | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Do you have twin element lights in the park light housing? If not then the park lights are just park lights when the light switch is in that position. They become turn signals only when the light switch is all on or all off. Two functions and only one light. When the light switch puts voltage to the park lights the flasher can not turn them off. Add a double contact base to the housing and move the turn signal wire to the brighter element keep the park light wire for the dimmer element and you will have both park and turn signals.
Steve H
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | "I have the double bulb in for park/turn" but do you have the two contact socket? if so, you might have the elements wired so the brightest one is 'park', so the dimmer one flashing doesn't show up
Bill | | | | | Joined: Apr 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 127 | After reading some more posts on the forum, I went back last night to take a look at a few things. I had the turn signal on the dim side of the bulb and the parking light on the bright side. So I switched them around and everything works like it should now. So you were both barking up the correct tree, thanks for replying guys. | | |
