1 members (Brian Moore), 95 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
Worked on unsticking a heat riser valve over the weekend. Successfully, I think. It is still a little sticky at the full open and full closed positions. My question is this: Are the holes in the manifold for the shaft bushed. It appears that on the end away from the counterweight that a bushing is still frozen to the shaft and is turning in the hole while on the other end the shaft seems to be freely turning in the bushing. The valve is welded to the rod. Should I attempt to get this apart? Are bushings available to re-bush this? Appreciate any reply
I have taken the valve out before to free it up. I ground the welds with rotary file, pulled the flap off and removed the shaft to clean up the holes. I don't remember there being bushings, but my memory sometimes lets me down. Of course you need a welder to put it back together.
Grant
1950 Chevy 3100
1952 GMC 150 (In Pieces)
1968 Chevy K20
1966 Shovelhead
1978 BMW 100S
Somebody makes a lube for these risers--I think you get it at NAPA--as I recall it has graphite in it. cool
Buzz'n Half Dozen
No bushings unless someone added them.
Fred
52 3600
69 C-10
