| | | Forums66 Topics128,165 Posts1,057,087 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | My dist. is held on by a simple clamp. The 4 vendors I checked do not sell the complete distributor clamp with vacuum advance, only the vacuum advance.
Any ideas who has new, complete vacuum advance dist clamps? | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Put an add in Parts wanted there are alot of them out there.
Pete | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | What is wrong with yours? There are three different styles, can you post a pic of the vacuum advance you have?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | is this on a 42 GMC
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | Currently I don't have any working vacuum advance linkages. The one that was on the dist in the 'box of parts' is not for the 235 dist (the clamp is to large.. does not grab the dist I have for the 235).
The motor is a 58 235 with a rebuilt dist from Advance auto. The dist clamp I am using was also in the box-o-parts. It fits the rebuilt dist but has nothing to hook an vacuum advance to.. its just got the clamp, a clamp screw, and a flange for the block hold down bolt.
I would prefer new, but I will post a wanted ad if I cannot find a new one. | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | That's what I have...... sort of.
Those will not work with the vacuum advance, correct?? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Is this what you need in combination with the part/collar/clamp shown at the links above?
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | On a side note, the distributor for my 235 I picked up at NAPA auto came complete with vacuum advanced and clamp Had the A R gauge stamped on it also ...pic... ...pic... | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | I went with the $70 Advance Auto dist because I though the vacuum linkage in the 'box of parts' was the correct one.
I'll run without it if I can't get one... just would rather have a bit more MPG out of the old beast. A G506 clocks in at about 8,000lbs empty... that's a lot to ask of a 130hp | | |
