11 members (KEVINSKI, Hotrod Lincoln, TUTS 59, Gdads51, Dusty53, Lonnie, klhansen, Geo55, Gray_Ghost, 2 invisible),
186
Mod | | | Forums66 Topics128,165 Posts1,056,999 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 3 New Guy | | New Guy Joined: Apr 2012 Posts: 3 | I am about to reinstall my intake and exhaust manifold on a 1956 235. when I removed them for paint and new gaskets, the sleeves were not installed before. So my question is do I need to buy and install the 3 sleeves or just put a new in/exh gasket on and go?
Also I had seperated the intake and exhaust from eachother and for reassembly do i need to bolt them together tightly or loosly before they are mounted to the engine?
Thanks in advance for the help!!
Building 1949, 1950, 1951 1/2 tons. Why three, cause one is never enough...
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | They are not needed, they just make it much easier to line everything up. I bolt the intake and exhaust loosely together and bolt the assembly to the head without the manifold to head gaskets first, then tighten the bolts, then remove and install manifold to head gaskets and reassemble.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | they aren't necessary, however I have no idea how you would get the intake lined up as accurately with the intake ports without them. Given the very poor breathing of these heads, I would use every resource available to me to get the intake flow smooth and unobstructed. And since they are so dirt cheap and readily available, I don't know why you wouldn't use them. Not to mention that during installation they are a great benefit. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Also I had seperated the intake and exhaust from eachother and for reassembly do i need to bolt them together tightly or loosly before they are mounted to the engine?
Thanks in advance for the help!! loosely, make the manifold to head then touque in sequence, manifold, then heat box, then back to manifold | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I have a used set you can have if you decide you need them. Free.
Drew
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Not necessary? You want me to believe GM went to the expense of buying and installing millions of parts that weren't necessary? I'm not buying it. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I'm not sure why exactly they used them on these engines, whether it was to expedite assembly, or to provide a smooth transition from one piece to the next. But the engine will run with out them, much like nearly every other engine on earth. Rendering them technically UN-necessary, however given the price of FREE, and knowing for absolutely sure the ports are lined up perfectly for all practical purposes. I see no reason NOT to use them. I do know I wouldn't assemble an engine without them. Unless of course I was marooned on a deserted island and that was my only way home. | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Not necessary? You want me to believe GM went to the expense of buying and installing millions of parts that weren't necessary? I'm not buying it. Me neither. They can easily be made from exhaust pipe if none are handy. See here.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Apr 2012 Posts: 3 New Guy | | New Guy Joined: Apr 2012 Posts: 3 | Thanks guys, sounds like i'll be getting a set ehh. I am new to 6 cyl world, been into v8's camaros, novas. This is my first 6 build, they were not installed on the engine i tore down and was not sure they were needed. the engine ran great, just looked a mess with all the old greese and rust.
I am building 3 trucks, 1949, 50, 51. love the look of these things
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | What is the manifold off of? Is it off the 56 or the 49,50 or 51? | | | | | Joined: Jul 2012 Posts: 93 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 93 | really old timers had told me years ago that without them the motors would miss and not idle smoothly--cant see why, but always used them. | | | | | Joined: Jul 2013 Posts: 17 New Guy | | New Guy Joined: Jul 2013 Posts: 17 | CRJ Pilot, off topic but who do you fly for? I'm a controller at ZNY and work the Airspace on J48/74/110/80/152 Q42 etc... | | | | | Joined: Apr 2012 Posts: 3 New Guy | | New Guy Joined: Apr 2012 Posts: 3 | I fly for air wisconsin so i bet i have talked to you at some point.
The intake is off a 1956 235, and it really did idle nice, no intake leaks.
| | | | | Joined: Oct 2012 Posts: 57 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 57 | i always use the sleeves.. but you have to be sure it is a 235 intake the 216 are a bit smaller and will not pull up all the way on a 235.. with them being missing i would make sure that is not why they were left off | | | | | Joined: Dec 2007 Posts: 140 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 140 | You still have these sleeves laying around?
Thx, Derek | | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | There are stepped sleeves available for installing a 216 manifold on a 235 head and keeping the ports and the manifold lined up. Jerry
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | They are easy enough to make, just use a piece of exhaust pipe slightly larger than you need, make sure to make them all the same length.
Ed
| | | | | Joined: Dec 2007 Posts: 140 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 140 | Thx all, just gonna get some from JJ Inliners | | |
