I coupled disc brakes on the front of my '42 1/2 ton with an S-10 rear end (drum). I want to keep the original brake/clutch pedal set up. Now I'm struggling with what to use for a master cylinder. What master cylinder should I use? Do I need to fabricate a mounting bracket. What about the right power booster? Where can I find the parts I need? Any advice is appreciated.
Thanks'
