4 members (Ponchogl, GRNHydra, TPR57C, stlcardinalsguy), 143 guests, and 1 robot.
Topics128,030
Posts1,055,430
Members48,422
#96927 08/31/2006 12:42 AM
Hi Guys, I just got my 55.1st series pickup to run and drive and stop. took it around the the block for the first time in many years. It feels good. My question is. Does any one know for sure if this truck could have been built 12v. The last owner says it was but he has proven not to be the most honorably man I have ever met. The bulbs are all 12v as is the generator. But while it runs the ampmeter is jumping down to full discharge and then back up constantly. I dont see any resistors mounted anywhere and cant find any markings on the voltage regulator. I want to go to 12v alternater soon but dont want to burn anything.
#96928 08/31/2006 1:45 AM
A '55 1rst will be 6 volt originally, trucks and the 6 cylinder Corvettes from '55 were the last 6 volt vehicles from Chevrolet. It certanly sounds as if you have a charging problem. you should first confirm that it's a 12 volt generator, it should say on the tag on the housing. Then check it with an ammeter to rule out a faulty dash guage. You should also check the volts output. If you are going to convert to an alternator anyway,you'll want to go through the entire system and make certain that it's compatible with 12 volts.
Bill Burmeister
#96929 08/31/2006 7:34 PM
Also check the battery not conclusive but!!!!!!! Peter
#96930 09/01/2006 7:39 PM
no marks on the regulator (or Generator) would seem to make it 6v stuff. my 54 came with a 6v generator and a 12 volt regulator and behaved like you discribe.
"It ain't a truck if you can't hose out the cab."
#96931 09/01/2006 8:09 PM
Old timer tip given to me years back as a Quick Telltale.....
If the tag is still on the Gen and its Silver with Red background-12 volts
Silver with Black background-6 volts.
Starters Too... wink
Regards
