| | | Forums66 Topics128,281 Posts1,058,464 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2013 Posts: 30 'Bolter | | 'Bolter Joined: May 2013 Posts: 30 | is the speedometer gear in my 58 chevy 1/2 truck different from say 55,56,57,59,60 being a plastic gear just different number of teeth? I have tried a few different gears and none seem to catch the spline gear inside trans, where can i get the correct gear for my truck? Thank you | | | | | Joined: Apr 2005 Posts: 2,103 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,103 | There are some differences. For example: 55-56 3 speed (non overdrive) trucks used a steel driven gear. Cars used a plastic gear. They are not interchangeable with each other as the drive gears are a different size. I'm not sure what year trucks started using a plastic gear - it may have been 58 or 59. You also may not have a 58 transmission in your truck as many things happen over the years. The number of teeth on the driven gear is matched to the rear end ratio. Various ones can be used. If nothing works perhaps the drive gear is damaged and needs to be replaced. Fred
