0 members (),
70
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 41 | Hey guys upgrading to a dual master cylinder and replacing all wheel cylinders and brake hoses on my 57. Would like to replace all steel brake lines as well. I need to know the correct diameter and pitch thread for these??? Also how many feet of piping should I buy? Thank you kindly! | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I just replaced all the hard & soft brake lines in my 49 3100 and I decided to try one of those premade hardline kits. Every piece fit just about perfectly and followed the originals contours just like they were OEM. All the flare fittings sealed on 1st tightening. If I had a good flare tool I would have considered making mine up but in my case it was cheaper to go prefabbed. Just an FYI. Good luck Dave | | |
