5 members (Denny Graham, Steelonsteel, 66flea, treegrower, Otto Skorzeny), 52 guests, and 1 robot.
Topics128,076
Posts1,055,924
Members48,430
Hey all
what should the stock compression numbers be on a 1955 261? (cold).
mine has a 848 head on it, and I did a compression test this morning, I just wanted to know how the numbers compare.
best regards
jay
what's most important is that all cylinders be close to the same, if there's a wide variation highest to lowest you should consider an overhaul
Gas Pumper
Gas Pumper
My numbers, recently tested on a 1958 261 with the 848 head are as follows:
138, 139, 138, 140, 139, 138
Hope this helps!
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
At least they're all similar. I don't know what the exact recommended numbers are.
Everything I've researched shows your in range. The sites i looked at said between 130-150 your in the middle with a 2psi difference. That's good I believe.
1955 2nd series 6 cylinder (Shop Manual) - on a truck engine that has been run for ". . several minutes and allowed to warm up and lubricate the valve mechanism", with all spark plus removed : 130 pounds or better with all 6 readings within 5-10 pounds of each other.
The things that effect compression checks are, your gauge may not be calibrated the same as the guys gauge to which you are comparing your numbers, and the barometric pressure on a given day affects the reading. This means that you could have different readings on different days with the same gauge if a high or low pressure weather front should role through on day two. Don't get hung up on the value of the actual number as long as the difference between cylinders is not significant. Could all cylinders/valves be worn exactly equal and give low readings within 2% of each other? Possible I suppose, but extremely unlikely.
I just check for normalcy. A digital thermometer is a great tool to check for proper combustion. Shoot each cylinder and exhaust port. By far the most accurate i think. Plus you don't have to remove the plug. I'm lazy...
I was wanting to know what a cold 261 stock engine would read.
the 130 number seems to be on a warmed up 261.
thanks everybody
A cold check will only tell you if you have a dead cylinder(no compression to speak of). You really need to do it on a fully warmed up and normalized engine to get usable data for comparing the individual cylinder pressure readings.
I did a cold check on my 261 with an 848 head and they were all in the 150 -155 range.
