Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Tyler Watts, Otto Skorzeny, BC59), 166 guests, and 2 robots.
Topics128,281
Posts1,058,464
Members48,490
#969012 09/03/2013 6:08 PM
is the speedometer gear in my 58 chevy 1/2 truck different from say 55,56,57,59,60 being a plastic gear just different number of teeth?
I have tried a few different gears and none seem to catch the spline gear inside trans, where can i get the correct gear for my truck?
Thank you
There are some differences. For example: 55-56 3 speed (non overdrive) trucks used a steel driven gear. Cars used a plastic gear. They are not interchangeable with each other as the drive gears are a different size. I'm not sure what year trucks started using a plastic gear - it may have been 58 or 59. You also may not have a 58 transmission in your truck as many things happen over the years.
The number of teeth on the driven gear is matched to the rear end ratio. Various ones can be used. If nothing works perhaps the drive gear is damaged and needs to be replaced.
Fred
