| | | Forums66 Topics128,034 Posts1,055,536 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#96896 08/29/2006 9:29 PM | Joined: Sep 2001 Posts: 100 Member | | Member Joined: Sep 2001 Posts: 100 | I though it would be a good idea to stick a third brake light low in the rear window of my '49 1/2T pu. I got what looks like a pretty good light from J.C. Whitney, and the Whitney catalog recommended adding a logic circuit it sold so the 3d light didn't blink every time I braked and signaled a turn. Wiring the logic circuit was easy -- one wire to left stop light, one to right, the last to the 3d light. I've got the 3d light grounded to the frame, but the light comes with loony pictures (no diagrams) and instructions just about translated from Chinese. So where does the 3d light get its power? From the brakelight switch ahead of the flasher? If it does, why all this business with the logic circuit?
Never start vast projects with half vast ideas.
#96897 08/29/2006 10:04 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Retread,
Good question. If you powered the light AFTER the brake light switch, but BEFORE and turn signal switching, it seems you could do without the logic circuit.
My bet is that the logic circuit was designed for new rigs where you couldn't access the brake circuit as easily before it gets confused in the turn signal spaghetti.
What would happen if you dumped the logic circuit, grounded the light and powered it from the switched side of the brake switch...it should light up on every brake application it seems to me!
Stuart | | |
#96898 08/29/2006 10:14 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I put one on my 70 & wired it directly to the stop light switch. Works fine. I believe all the other setups are for cars were you come off the back lights & it uses diods to prevent the light from flashing. I did put a fuse in the wire so if it shorted out it would not interfear with the other circuits. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#96899 08/29/2006 10:34 PM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Sorry you lost me when you used the term pretty good part and JC Whitney in the same sentance.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | |
#96900 08/29/2006 10:54 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | True, but interjected in that 'sentance' was the give away word we all dread...CHINA!
Stuart | | |
#96901 08/29/2006 11:48 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i just used a red clearance lamp (double filiment) from 'flaps' and it works great, @ only $3.00 in my neighborhood. i wired the two filaments together and connected that one wire to the brake lamp wire & drilled two holes. this clearance lamp grounds thru the mounting bolts to the chassis. done in 1/2 hour.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#96902 08/29/2006 11:59 PM | Joined: Sep 2001 Posts: 100 Member | | Member Joined: Sep 2001 Posts: 100 | Okay. Thanks to all. Direct from the brake light is how I saw it. I'll give that a try then look into the dual filament fix. And, well yeah, I thought, how can JCW foul up a simple thing like a light. You have to see those instructions.
