0 members (),
89
Mod | | | Forums66 Topics128,271 Posts1,058,313 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | This may seem odd, but: I have a leak from the trans that appears as if it leaks through the speedometer cable housing (metal). It doesn't leak at the connection, the leaks appears at the low point of the cable. There is no trace of fluid on the cable except at the point of the leak. This is a new cable, going to a three speed OD trans. It seems the speedometer gear (in the trans); where it meets the cable, there is no seal or good mating surface. And, the fluid then can run into the cable liner. However, this cable seems to be the same as the old one. Any ideas would be appreciated, I just can't see how fluid could be inhibited from leaking into the cable. Thanks, don | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Is it possible your trans is over full? The speedo gear should be above the oil level and any oil that gets splashed while moving should not get past the reverse spiral groove in the gear shaft.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | That could very well be, I did fill it as much as it would hold. Thanks for the info. don | | |
