| | | Forums66 Topics128,281 Posts1,058,462 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2013 Posts: 30 'Bolter | | 'Bolter Joined: May 2013 Posts: 30 | Hi, I have a 58 chevy truck, 235engine, stock rearend and 28" tires, spd manual trans, ... saw where you recommended going to a 3spd overdrive trans , can you tell me what years would fit my truck, what overdrive trans will fit my truck?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the OD 3 speed was offered in GM trucks from 55 on up - in about 68 it changed slightly, but will still work - also available for cars, also workable
Bill | | |
