Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (41 chev), 120 guests, and 2 robots.
Topics128,275
Posts1,058,572
Members48,492
I have a 58 chevy 1/2tn truck original drive train, 6cylinder, 3spd manual, 4.11 rearend, 28" tires.... tops out at about 48mph, randys ring and pinion offers a 3.23 ring and pinion that will fit my rear, What I am wondering is how much it will increase my top end speed?
I just checked Randy's web site and I only see the 3.38 gear set, which is the Chevrolet optional automatic ratio.
My Blog
if you have the standard 3 speed [not overdrive] and original rear, you have a 3.90 rear gear, the 4.11 came with the overdrive trans, and as Dave says, the 3.38 is what's available, started in '58 as a 'mileage minder' option .... your tires are smaller than original, but if you can only get 48mph with a 3.90 rear [or even 4.11] you have a faulty speedo, a tired engine, or you're just afraid of the noise wink
Lancer, I too am interested in this information. I hope you don't mind me sharing, or jumping on your post, but I have been meaning to ask this question or similar also.
I have 53 1/2 ton, 216, T5 with .87 5th gear 29" tall tires and HO33 rear end (55-62 which I have been told is 3.90 or 4.11's.
My top speed is 53 at 3000 rpms. Engine sounds and feels much better at 2800. I don't have speedo hooked up, but my daughter followed me home from a cruise in on a local 55 highway and said that was my average speed.
Now while I am happy with the way it runs, I just need a few more mph's because this is my daily driver. I would like to be at 2600-2800 rpms at 65-68mph. I am going to change out rear end completely and am also wondering what ratio to use. All the calculators I seem to find online are way off when I feed my info into them so I'm a little confused.
So Lancer, I too am interested in this response also as our top speeds are close to the same. I was thinking 3.23's?
I am also changing to disc brakes up front and bigger drums on the rear even though I have just rebuilt all cylinders and installed drums, pads, spring etc. I feel it will not stop as well at the extra 15 or so MPH's I'm looking for.
Phil
Thanks, it likely is a 3.90 and Randys is offering the 3.38 will this increase my speed by more than 10mph???? I'm just wondering if it is worth the cost and work. ..you are right it will go faster but at about 50mph the sound does get loud and feels like it is toping out
using the RPM calculator at the bottom of this page:
4.11 rear ratio
28" loaded diameter tires
1.0 transmission final/highest gear ratio
48mph at approx 2400 RPM
3.38 rear ratio
60mph at approx 2400 RPM
65mph at approx 2600 RPM
3.90 rear ratio
29" loaded diameter tires
53mph at approx 2400 RPM
3.90 rear ratio
0.87 transmission final/highest gear ratio
70mph at approx 2800 RPM
what gaining more top speed is "worth" is your call - as Tim points out, you can get more speed at the same RPM, but you can also run the truck at higher RPM than you currently are, maybe just need to add a tach and some sound insulation, you should be able to run 2800-3000 RPM without problems, although as Phil points out, keep stopping in mind .... then of course taller tires will help, and there's always the possibility of finding an original overdrive 3 speed [0.7 ratio] that would bolt right in somewhat cheaper
Tim,
Heres where I'm confused. I wrote my specs in my post above hoping the response for lancer would help me too, however, if I input my info into the calculator you posted, it would seem to make my rear end ratio around 5.40 or so. So what am I missing here? Is my tach wrong? Seems to be right. Idles around 600 or so. With my setup it seems with the .87 OD I should be doing 65 now at about 2600 or so. Could me ho33 rear be different? I'm lost here...
Sorry.
Phil
Oh my gosh, I really am an idiot!
Right after I finished my last post on here about maybe my tach is wrong, it hit me...no, can't be, well maybe? So I went out to the garage and unscrewed my Sunpro tach, and there it was...I had it on 4cyl!
So I have been riding around every day with the t5 thinking at 53 mph I was taching 3000 Rpm's, when really I was taching less!
Sorry Tim, the site you posted is about dead on now. I actually took a quick ride down the highway and back just now and was keeping up with traffic no problem.
I guess I'm getting old...thanks all!
Phil
Phil,
Good job figuring this out. I make these "doh" mistakes all the time - that it why I never mind someone making me recheck my measurements and my assumptions.
Now you can cruise with greater satisfaction.
