0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2013 Posts: 34 | I replaced my fuel pump, and in the process drained out some of the fuel in the line from the pump to the carb. Do I need to bleed this line or should the new pump just push this air through the carb when I crank it?
Thanks!
Trooper Jeff If I can't drive my truck, fetch my horse "Courage is saddling up even though you are scared to death" - John Wayne
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | It will push it through, and should pull it from the tank. | | | | | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | Trooper Jeff I have a 49 that If I am lucky get out once or twice a year. I have placed a "performance" type fuel filter right in front of the carb. This way I can see when the gas has gotten to the Carb. When I say "performance" type I mean it is one of the fuel filters that has a replaceable element and is clear. The are usually found in the performance section of your local auto parts store. Just be patient as this could take a little time.
Good luck
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | Prime your Carb with raw fuel before you start cranking Thus saving your starter while you are getting fuel fill the bowl. Jerry Jerry
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you have ran it recently there is still gas it the carb. It will bleed its self. Just start it up. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
