4 members (UtahYork, 3B, dt235sd, Shardean), 118 guests, and 2 robots.
Topics128,031
Posts1,055,433
Members48,422
#968443 09/01/2013 2:20 PM
I replaced my fuel pump, and in the process drained out some of the fuel in the line from the pump to the carb. Do I need to bleed this line or should the new pump just push this air through the carb when I crank it?
Thanks!
Trooper Jeff
If I can't drive my truck, fetch my horse
"Courage is saddling up even though you are scared to death" - John Wayne
It will push it through, and should pull it from the tank.
Trooper Jeff
I have a 49 that If I am lucky get out once or twice a year. I have placed a "performance" type fuel filter right in front of the carb. This way I can see when the gas has gotten to the Carb. When I say "performance" type I mean it is one of the fuel filters that has a replaceable element and is clear. The are usually found in the performance section of your local auto parts store.
Just be patient as this could take a little time.
Good luck
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
1 Offline
Prime your Carb with raw fuel before you start cranking Thus saving your starter while you are getting fuel fill the bowl.
Riding in the Passing Lane
If you have ran it recently there is still gas it the carb. It will bleed its self. Just start it up.
1972 Chevy c10 Cheyenne Super
