| | | Forums66 Topics128,115 Posts1,056,626 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 127 | Ok so I just put a new wiring harness on my 54' chevy. It came with everything but a flasher. So where do you put the flasher in the wiring? Is it before the brake switch or after. I assume the turn/brake function use the same wire. Thanks guys | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What type of turn-signal set-up do you have?
| | | | | Joined: Apr 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 127 | It will be coming out of the cup under the steering wheel
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | You will have to splice into the standard harness lines using your leads from the cup under the steering wheel as shown in these diagrams, starting on page #3. | | | | | Joined: Apr 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 127 | Thank you!!! This makes since now. | | | | | Joined: Apr 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 127 | My new harness came with all the wires for turn signals they just didn't tell where the flasher went . | | | | | Joined: Apr 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 127 | I have one more question. On page four the three wires going to the flasher are yellow, pink and black. So is the pick the power and the black the ground? Thanks. | | | | | Joined: Apr 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 127 | Okay one more question, were should I put any inline fuse and what amp should they be? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 |
I use a 14 amp inline fuse Placed it on the wire going to the X post on the flasher.
pink wire on your diagram | | | | | Joined: Apr 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 127 | ok so "X" is the power, "L" is for the lever switch and "P" goes to the indicator bulb, which on the bottom of my odometer. One bulb for both directions I think. Is this correct?
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | yes Page 5 on Tims link shows black for the pilot light.
