0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 97 | Just installed a rebuilt speedo in my '56 3200. It registers the same as my old unit (goes to 10 then up to 20). The odometer part does work on the newer unit but only show o.5 miles per mile. It runs smoothly. I am thinking I have the wrong or damaged gear in the stock 3 on the column trans. Any Ideas on the proper color of the gear I should have? I have not yet taken the cable loose from the trans. Are these speedo gears still available? Tom | | | | | Joined: Oct 2010 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 97 | I am waiting for my ring & pinion order from Patrick's (3:38). I think I will wait until it is installed and check the cable and gear then. I will then have all the changes done and can see what adjustments are needed. Tom | | |
