| | | Forums66 Topics128,060 Posts1,055,837 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2013 Posts: 34 | I'm trying to remove my fuel pump on my 55.1 3100, but one of the fuel lines won't come off. I assume I only need to turn the nut on the fuel line fitting to remove it? Or is there something I'm missing?
It appears that I'm working with the original pump and line. Could the fittings be so corroded that it won't move?
If so, would I better off removing the old pump with the old line (leading to the carb) still attached and just replace them both?
Thanks!
Trooper Jeff
Trooper Jeff If I can't drive my truck, fetch my horse "Courage is saddling up even though you are scared to death" - John Wayne
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Use a wrench on the adapter that is screwed into the pump, then use a flare wrench on the line. They can be real tight. Is the nut messed up from someone in the past using a vice grip on it? If it's messed up you should get a new nut put on along with a new inverted flare. | | | | | Joined: Feb 2013 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2013 Posts: 34 | Liberal spraying with break free and the two wrenches did the trick! Line is off and the nuts are still intact.
Thanks!
